archer12
Jan 06, 2019Aspirant
Range Ext wont work with Apple devices
I have wifi router (ATT Uverse) thats feeds EX7000 range extender. Any Apple products hooked to the extender do not connec to internet. They do connect to the extender, but there is no network con...
schumaku
Jan 06, 2019Guru - Experienced User
Reads like you have already installed the current EX7000 firmware (1.0.1.78) which is known to cause this (and some more) issues.
Head to https://www.netgear.com/support/product/EX7000.aspx#download , select "Previous versions", download 1.0.0.66, unpack the ZIP archive. The EX7000-V1.0.0.66_1.0.126.chk is the file you want - do not to double click or open, but to upload manually to the extender using it's firmware update function. Once done so, factory reset using the reset button (press about three to five seconds) and release. Then re-configure it from scratch as shown in the Quick Start Guide.
- archer12Jan 06, 2019Aspirant
Thank you!. I did as above and can confirm I am now running the previous firmware V1.0.0.66 as mentioned above. I also turned off the 2G and now only have the 5 G running which changed to port settings from auto to a fixed on the mywifiext setup page. However, I still have the same issue with Apple products not connecting through. I can sometimes get a partial page and then it stops. With a Windows computer or phone there is no issues. But with an Iphone, Ipad or Mac, I get no internet connections.
- Christian_RJan 08, 2019NETGEAR Employee Retired
- archer12Jan 08, 2019Aspirant
Yes, did factory reset after installed old firmware. So some more troubleshooting: I occaisionally do get a webpage when using Apple products now, but most pages do not load. I have the extender connected to my Uverse internet. But I also have an Apple Airporter device so I synced the extender to that unit with the same results. If the extender is basically just a repeater, then I figured the Apple Airport device would work, but it doesnt. I get the same results. I wonder if the extender is scrambling the IP or someother part of the address?
Thank you!
