archer12
Jan 06, 2019Aspirant
Range Ext wont work with Apple devices
I have wifi router (ATT Uverse) thats feeds EX7000 range extender. Any Apple products hooked to the extender do not connec to internet. They do connect to the extender, but there is no network con...
Christian_R
Jan 08, 2019NETGEAR Employee Retired
archer12
Jan 08, 2019Aspirant
Yes, did factory reset after installed old firmware. So some more troubleshooting: I occaisionally do get a webpage when using Apple products now, but most pages do not load. I have the extender connected to my Uverse internet. But I also have an Apple Airporter device so I synced the extender to that unit with the same results. If the extender is basically just a repeater, then I figured the Apple Airport device would work, but it doesnt. I get the same results. I wonder if the extender is scrambling the IP or someother part of the address?
Thank you!
- Christian_RJan 15, 2019NETGEAR Employee Retired
Hi archer12,
I have sent you a message. Please respond at your earliest convenience.
~Christian
