jailbee
Feb 04, 2019Aspirant
Range extender connection issues
Hi
I am having ongoing WiFi connectivity issues when a device connects to the extender it will not
Subsequently hand-off from the extender to the main router. (TPLINK WP841) when it leaves ...
Christian_R
Feb 07, 2019NETGEAR Employee Retired
Hi jailbee - Have you tried setting up the extender with the same SSID as the router to see if the issue persists? Wireless clients won't hand-off as easy without the same SSID.
~Christian
- jailbeeFeb 13, 2019Aspirant
Thanks for the advice - good call.
unfortunately, I have tried that and as far as I Can tell the hand off was unsuccessful, although I could not tell which router / repeater I was connected to once they had the same SSID. Although the devices connect to the router there was no internet connection.
i continue having to reset the router....so frustrating
thanks agsin
