OldWolf's avatar
OldWolf
Range Extender EX3700 setting up 5GHz but not 2.4
Hello,
I just bought a Netgear AC750 (Model EX3700) range extender to work with my Nighthawk X4S AC2600 (Model D7800) router.
Setup worked fine after a few unsuccessful attempts but with an oddity: On my router I have set up four wifi networks: 2.4GHz and 5GHz, and the same two as guest networks.
The manual says if the router supports 5GHz, establish the WPS connection twice, which I did.
The range extender only set up _2GEXT and _5GEXT for the 5GHz connection (and they both work fine) but not for the other three networks.
I was keen to try the 2.4GHz connection to the router because I think that the signal may actually be stronger. Not that bothered about the two guest networks.
Did I do something wrong or is this normal?
I am on a Mac (latest OS). Not sure where to find the firmware version for the extender, but the firmware for the router is the latest version.
Thanks for any information that can explain the situation.
  • plemans's avatar
    You can only extend 2 of the radio's. You have to choose the regular or the guest but not both.
    Have you tried logging into the extender via mywifiext.net and manually configuring the other radio?
    And if _2GEXT and _5GEXT  are both displaying, how do you know that one of the radios isn't connecting?
    Here's your manual with instructions for setting up the extender manually instead of via wps.
    https://www.netgear.com/support/product/EX3700
    • OldWolf's avatar
      OldWolf
      Hi plemans
      Thank you for this. The first issue with the regular and the guest network - I suspected that much, just wasn't sure. Thank you for the confirmation.
      Both, _2GEXT and _5GEXT are displaying and I can connect through them. On the router, the 2.4 and 5 networks have different names. This is how I know that they both connect to the 5Ghz. This isn't a problem but it would have been interesting to see the difference.
      Thank you again. Oh, and you confused me with the word 'radio' ... :)
      Best regards
      Wolf
      • plemans's avatar
        OldWolf wrote:
        Hi plemans
        Best regards
        Wolf
        so you have a 2.4ghz radio and a 5ghz radio. they function differently. The section you wrote  "This is how I know that they both connect to the 5Ghz. "  They can't both connect to the 5ghz. The ex3700 has dual band radio's but they're specific to the frequency they're designed to function on. If you log into the router and take a screen snip of your radio connections, what do you get?
