Chriiisss
Nov 27, 2015Aspirant
Range Extender ex7000 network issue
Hello. I bought the Nighthawk range extender ex7000 today. I configured it correctly, it worked fine. After a few hours I got ping issues, Which I didn't have before. My ping goes up to 400+ t...
Babylon5
Nov 27, 2015NETGEAR Employee Retired
In what mode have you configured the EX7000? Is it set up as an Access Point or Extender, if extender are you using one of the Fastlane options? What is the base station that the EX7000 connects to?
Chriiisss
I have it set up as an extender, and I'm not using the fastlane options.
- Babylon5Nov 27, 2015NETGEAR Employee Retired
What is the base-station? Is it and/or the client devices dual band? If so then Fastlane could make a significant difference to performance.
- ChriiisssNov 27, 2015Aspirant
My router is dual band, but not all of my devices are dual band.
Well in that case you could try using Fastlane with the connection from the extender to the router using the 5GHz band. You may possibly have range issues with that though, but it might be worth testing it out.
