Chriiisss
Nov 27, 2015Aspirant
Range Extender ex7000 network issue
Hello. I bought the Nighthawk range extender ex7000 today. I configured it correctly, it worked fine. After a few hours I got ping issues, Which I didn't have before. My ping goes up to 400+ t...
Chriiisss
I have it set up as an extender, and I'm not using the fastlane options.
Babylon5
Nov 27, 2015NETGEAR Employee Retired
What is the base-station? Is it and/or the client devices dual band? If so then Fastlane could make a significant difference to performance.
- ChriiisssNov 27, 2015Aspirant
My router is dual band, but not all of my devices are dual band.
- Babylon5Nov 27, 2015NETGEAR Employee Retired
Well in that case you could try using Fastlane with the connection from the extender to the router using the 5GHz band. You may possibly have range issues with that though, but it might be worth testing it out.
I'm having range issues, how is it possible that I'm having ping issues using my lan cable?
I never experienced these problems with my router.
I wanted to buy a range extender to connect my devices via cable but apparently that does not work either
