Xavi2503
Mar 20, 2017Aspirant
Range Extender for an R7800
Hi All,
For my home network i am gonna buy the Netgear R7800 but furthermore i am searching for an good range extender for those spots where the wifi won't reach.
I checked the netgear website and i am doubting on 2 models
EX6150 & EX7300
Was wondering if somebody can give my their opinion / advise or maybe suggest even an whole other model ?
Furthermore i am wondering if i can use the same SSID on my router as on the range extenders ? So i don't need to change everytime from wifi spot.
Hoping you can advise me
Thanks in advanced
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Xavi2503
You can use the same ID as it is not recommended your devices will not automatically change to the extenders network you have to do that.DarrenM
