Redsnake
Feb 03, 2019Aspirant
Range Extender keeps loosing wifi connection
This concerns an extender which is connected to a router. I connect the extender to the router by pressing the WPS-button on the router and then the "push "N" connect"-button on the extender. The ext...
Christian_R
Feb 07, 2019NETGEAR Employee Retired
Hello Redsnake,
A couple things:
1. Have you tried moving the extender closer to the router?
2. Macbook, iPhone, and devices that are connect to the extender are unable to get internet connection when the issue occurs? Is this on all devices within your home?
3. Does the extender have the same SSID as your router?
~Christian
Redsnake
Feb 08, 2019Aspirant
Dear Christian, thanks for replying.
1. The extender is well within reach of the router.
2. Yes, all devices loose WiFi from the extender (but WiFi from the router still works).
3. How do I check/change Ssid?
Brgds
Brgds
- Christian_RFeb 08, 2019NETGEAR Employee Retired
Hi Redsnake,
You can change the SSID of the extender through the extender's admin page. Using a device connected to the extender's network and browse to mywifiext.net and go to the wireless settings to change the SSID (Network name).
~Christian
