mmcalisterky
Oct 30, 2018Follower
Range Extender no longer working
I have been using a range extender for the past couple of years, but it is no longer working. The main modem/router is functioning, but when I go through the setup process by pressing the WPS button...
- Oct 30, 2018
Hi mmcalisterky,
Welcome to the community!
You can try manually setting up the extender instead of using WPS. The steps are described on this link.
Dexter
Community Team
DexterJB
Oct 30, 2018NETGEAR Moderator
Hi mmcalisterky,
Dexter
Community Team
DexterJB
Nov 05, 2018NETGEAR Moderator
Hi mmcalisterky,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
