Spender1330
Jan 17, 2017Aspirant
Range Extender rpt v3 wont ignore BT Hotspot
Our extender had worked for months but recently lost the ability to connect to the net. It can still extend the network it "sees" but there appears to be no Internet connection from that source. ...
Spender1330
Jan 27, 2017Aspirant
Hi Darren
It does yes, or at least it does on a mobile phone or laptop. The extender seems to latch on to whichever one randomly. Can it be "locked" to one, or ignore the other maybe. I couldn't see how to do it under settings - which I can only access when it's on the right one (the non hotspot one!)
- DarrenMJan 27, 2017Sr. NETGEAR Moderator
Hello Spender1330
You may want to factory reset the extender and connect it to the router using WPS this may stop it from jumping to the hotspot.
DarrenM
