dioguardinho
Aug 16, 2015Aspirant
Range Extender WN300RP
Hello... I have Range Extender WN300RP, but I have a problem. I can connect my extender with my router, and it's ok. If I try to connect a pc with cable to my extender, I have Internet and all work g...
dioguardinho
Aug 19, 2015Aspirant
Hi Nhann, I used WN300RP with another router and It worked. Now I change router (Tecnhicolor TG788vn v2, this is link http://www.fastweb.it/myfastpage/assistenza/guide-fisso/configurazioni/modem-fastweb/technicolor_tg788vn/) and I have WN300RP v2.
nhann
Aug 24, 2015NETGEAR Employee Retired
When you changed your router to the Technicolor TG788VN, did you also reset your Extender to factory default and complete the installation?
Page 26 of 36 http://www.downloads.netgear.com/files/GDC/WN3000RPV2/WN3000RPv2_UM_2April2014.pdf
