Jofear's avatar
Jofear
Follower
Jul 08, 2016
Range extender
I am trying to extend the range using the above product and can see the extended net work but it requires a password. The instructions say use the password for the router but this is not working.
Help please.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Jofear
    You can try to use the WPS method but if the router password is not working after setup you may need to factory reset the extender and try the setup again.
    DarrenM
