sykotron
Mar 13, 2018Aspirant
Can't access extender setup on WN3000RPv3
Trying to set up range extender connected via ethernet wire to a 5 port switch that's connected to a netgear router, but I can't access the extender setup page. The extender shows up on the network d...
- Mar 15, 2018
Hi sykotron,
Did you tried accessing it using the IP address for it which you find in DHCP client list on your router and see if you can access its settings?
jvasanth1984
Mar 15, 2018Virtuoso
Hi sykotron,
- sykotronMar 15, 2018Aspirant
Yep, accessing the local IP address of the extender worked just fine. Thanks!
