gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
DexterJB
Oct 16, 2018NETGEAR Moderator
Hi all,
We are currently looking into this issue and will provide a response once available.
Dexter
Community Team
VS228
Dec 27, 2018Tutor
After the firmware update to V1.0.1.78_1.0.140, my range extender shuts down intermittently. Then I have to power off the mains and put it on again. Please fix the firmware quickly!
- Zalmoxis_12000Dec 27, 2018Tutor
Try to revert it to the old one as I did and now everything is back to normal. have a look above, someone put the link to the previous firmware.
- DLGMAXDec 31, 2018Tutor
Any news on an updated firmware fix for this issue? My EX7000 started dropping connections recently like others have been experiencing. I found this thread and checked my firmware and yep, it is version: V1.0.1.78_1.0.140. I have not yet tried to roll back to the last version of firmware, thought I would ask about a fix from Netgear first. Thanks for any updated info/help that can be provided!
- RealPiDec 31, 2018GuideNo news. The firmware update is bugged. Netgear are pretending to not know about it even though this thread has been talking about this since Sep, so for 3 months.
The only solution is to downgrade to previous firmware, follow my instructions on this thread with link.
I will write a negative review on Amazon, reporting Netgear's behaviour and will also report this on social media, since otherwise Netgear will continue ignoring us. I recommend you do the same thing.
