gliu
Oct 03, 2018Guide
EX7000 Wifi Range Extender Dropping out after upgrade latest Firmware
Hello
Range extender recently upgraded to latest release version EX7000-V1.0.1.78_1.0.140. Now the extender keeps on dropping off usually for around few seconds. The signal received from Linksy...
Mar 19, 2019Guru - Experienced User
Can you downgrad the EX to the last working FW version?
LordPurple wrote:
I did not have much luck with the new firmware, which I got from Christian. After it was loaded, the extender factory reset, reconfigured - no devices could successfully attach to the extender - meaning, they could connect to the 2G or 5G WiFi network (layer 1/2) but were not given a routable DHCP address (layer 3) so they would show "No internet connection". The link from the extender to the base router (Netgear C3700) was fine, as I was able to log into the extender from the router network and the status page showed everything normal. This is basically the same pathology I had with the last (bad) firmware. Several extender reboots and factory resets as well as a reset of the base router did not help, so I've reverted to the previous (1.0.0.66) version and all is well again. I reported my experience to Christian, who did say there may be another test version soon.
LordPurple
Mar 19, 2019Star
Yes - that is what I said above - after the test FW did not work, I reverted to the "1.0.0.66" version. As long as you can connect to the extender, you can downgrade the FW.
- FURRYe38Mar 19, 2019Guru - Experienced User
Ah ok, kewl. Hopefully next FW will fix what ever is broke in the last version. :smileyfrustrated:
