Turbojr74
Jul 23, 2019Tutor
EX8000 1.0.1.202 Firmware slow 5Ghz
Just did the FW v1.02.202 and twice this cutout after so many hours and would not allow internet connection. After the second failure, I then saved config settings, downloaded the FW and flashed the...
A_Plumbus
Nov 09, 2019Aspirant
I am getting supotimal/poor performance from the 5GHz bands on my EX8000 as well when setup as a WAP and wired into my XR500 router. Did you ever get it to work as it should?
Turbojr74
Dec 06, 2019Tutor
I have not - been hit and miss really.
I can get higher speeds from tested devices just connected to 5ghz of the R7800 in the area where the ex8000 is at.
Connect those same devices to the 5ghz of the ex8000 and there is a significant loss.
