Colveu
Feb 22, 2017Aspirant
Imposible to manage USB sorage
When I try to add or modified a file on my HD on USB storage I receive the following message; Impossible de copier les éléments vers « USB_Storage » parce que vous ne disposez pas de l’autorisati...
Colveu
Feb 25, 2017Aspirant
Hello,
THank you for your reply.
My MBP system files is HFS+
I understand that could be the problem ???
Colveu
Mar 02, 2017Aspirant
Hi,
To day I tried with a new HD in Fat32.
All is working well
Conclusion HSF+ is not really supported by Netgear products !!!
Best regards to all
- schumakuMar 02, 2017Guru - Experienced User
Colveu wrote:Conclusion HSF+ is not really supported by Netgear products !!!
Thisis not limited to Netgear - all system integrators of these non-native file systems (there are two vendors, but that's not relevant) suffer under some variable conditions on HFS/HFS+ file systems. About what I had mentioned above already.
Thank you again for the feedback.
-Kurt
