Deuga2
Apr 25, 2015Novice
New Router, Now I Can't Connect
Have a WN2000RPTv2 extender. It was working fine with my old router. Now have a new router and my pc can't find it to enable setup. I've tried all the possible setup options in the install guide but ...
lurzan
May 15, 2015Novice
LBear,
If the new router you have bought is a Netgear router, then you don't have to pay for the support. But if your new router is not a Netgear router and the extender is also out of free support warranty, then you will need to pay for the support. There are several support options but if you doesn't require 3rd party support options and just wants to fix the extender's issue, you can select the PPI option which will cost you $39.99 to fix one particular issue.
