Cheshire_vinny
Jul 06, 2022Aspirant
Nighthawk 7700 internet not working on all devices
Hi, I have recently set up my EX7700 and it is extending my Virgin Hub 3 router, I have it set to same SSID details for a seamless transfer, however not all the devices when transferring to the exten...
Jul 07, 2022Guru - Experienced User
You can try going into the virgin hub and setting the extender with a static ip address.
I haven't really found a good solution for the virgin hub 3 as there's been numerous posts on here and virgin about adding extenders to it.
The ISP supplied routers really give routers a bad name.
Cheshire_vinny
Jul 07, 2022Aspirant
So have done that via the extender and the devices with the issues got internet connectivity back! Lets see if this holds up over the next 24hrs, thanks for the suggestion and help, will let you know.
