Cheshire_vinny
Jul 06, 2022Aspirant
Nighthawk 7700 internet not working on all devices
Hi, I have recently set up my EX7700 and it is extending my Virgin Hub 3 router, I have it set to same SSID details for a seamless transfer, however not all the devices when transferring to the exten...
Jul 07, 2022Guru - Experienced User
You can try going into the virgin hub and setting the extender with a static ip address.
I haven't really found a good solution for the virgin hub 3 as there's been numerous posts on here and virgin about adding extenders to it.
The ISP supplied routers really give routers a bad name.
Cheshire_vinny
Jul 07, 2022Aspirant
sadly that lasted 6 hours then off they went again….time to admit defeat and send it back and try another brand. Thanks for your help though.
- plemansJul 08, 2022Guru - Experienced User
You might check with virgin. Yours isn't the only device thats had issues with that router but I think they make their own extender
