boblinthewild
Mar 30, 2018Tutor
Setting up range extender with base router SSID broadcast turned off
All of the range extender installation manuals just say to select the base router SSID (and enter the password) to connect. But I don't see an option to manually enter the SSID of a router whose SSID...
- Mar 31, 2018
Hi boblinthewild,
This is possible. You need to scroll to the bottom of screen when it shows list of existing networks where you'll have a choice to enter SSID manually and input security type and passphrase of your existing network to setup extender with routers whose SSID is hidden.
jvasanth1984
Mar 31, 2018Virtuoso
Hi boblinthewild,
- boblinthewildMar 31, 2018Tutor
Thanks! My new Netgear extender is coming tomorrow, so this comes at a perfect time. Much appreciated.
