grzego80
Feb 27, 2018Aspirant
WN3100RPv2 - much slower data transfer through wifi from extender than wifi from main router
Hello all, my wifi configuration looks like this: NETGEAR genie shows signal strength is 144Mbps. The band used is 2,4 GHz. I can't resolve the issue, that when I connect my laptop to gkwla...
jvasanth1984
Mar 04, 2018Virtuoso
Hi grzego80,
Try to perform soft reset and try reconfigure it to see if you witness this issue.
grzego80
Mar 05, 2018Aspirant
No changes, unfortunatelly. But I've asked on another forum, and it seems, like this is normall extender behavior, as it must send and receive signal with the same antenna (or smth like that).
- jvasanth1984Mar 06, 2018Virtuoso
Hi grzego80,
This was normal in few instance when it comes for wireless.
