bexem's avatar
bexem
Follower
Nov 28, 2014
Reboot on device disconnect
Hi ti everyone,
I have a problem with this my new netgrar pr2000, I use this to extend my home WiFi network with another name, with two lan devices attached and (minimum) my PC and smartphone via wireless. Everything is fine until I shutdown one of my WiFi device, example if i put in standby my notebook (connected via WiFi to the pr2000) after some seconds the trek restarts its self...I've tried "playing" with the advanced settings but nothing! I tried already to power the trek with USB and/or the AC but nothing. Firmware updated to the lasted one...
Someone can help me please?
Thank you
  • I'm having the exact same problem. Sometimes it reboots when I connect a device, sometimes it reboots when i disonnect a device. I've already had Netgear RMA one device, and now the second device is doing the same exact thing literally right out of the box - absolutely no change to the default configuration. Anyone found a fix? I'm on the phone with Netgear support and they have no idea.
    • nhann's avatar
      nhann
      NETGEAR Employee Retired
      Hi pumrum,
      It looks like this issue has occurred before for other users.
      If you have not already done so:
      Please contact Support and provide them with your PR2000's config file so they can help troubleshoot.
