cavan
Sep 07, 2024Aspirant
Receiving ERR_SSL_BAD_RECORD_MAC_ALERT when using extender
We are at our wits end.... We have a CAX80 (Firmware 2.1.5.2) and have no issues with it and it does great. We recently moved and our wifi speed dropped from ~200mbps at the router to ~55mbps in...
Sep 22, 2024Guru - Experienced User
Only happens with the EAX80 enabled and connected at the EAX80?
cavan
Sep 24, 2024Aspirant
Yes, only when the extender is in use. We have tried connected via ethernet and via wifi and nothing works.
- FURRYe38Sep 24, 2024Guru - Experienced User
You might update the CAX80. I'd factory reset both CAX80 and EAX80 and setup from scratch afterwards. Then check that site with different browsers. Try a different PC to compare results. https://community.netgear.com/t5/Cable-Modems-Gateways/New-CAX80-Firmware-Version-5-1-1-8-Released/td-p/2396719/jump-to/first-unread-message
