cavan
Sep 07, 2024Aspirant
Receiving ERR_SSL_BAD_RECORD_MAC_ALERT when using extender
We are at our wits end.... We have a CAX80 (Firmware 2.1.5.2) and have no issues with it and it does great. We recently moved and our wifi speed dropped from ~200mbps at the router to ~55mbps in...
cavan
Sep 24, 2024Aspirant
Yes, only when the extender is in use. We have tried connected via ethernet and via wifi and nothing works.
Sep 24, 2024Guru - Experienced User
You might update the CAX80. I'd factory reset both CAX80 and EAX80 and setup from scratch afterwards. Then check that site with different browsers. Try a different PC to compare results. https://community.netgear.com/t5/Cable-Modems-Gateways/New-CAX80-Firmware-Version-5-1-1-8-Released/td-p/2396719/jump-to/first-unread-message
