jdefazioaz
Jun 17, 2020Guide
Reconnecting extender: can't see NETGEAR_EXT
After changing my wi-fi password, now trying to reconnect my extender. On my laptop or tablet, the extender network, NETGEAR_EXT, is not showing up.
Note: all was working fine an hour ago when I decided (stupidly) to change my wi-fi pw. I should not have done that, now I can't reconnect the extender.
Have you tried a simple factory reset and then re-installing the extender?
Push and hold reset for 7-15 seconds while powered on. then follow the install guide for it.
Yes, did a factory reset, still stuck. At the step where it says "now go into your device's network settings menu and connect to your network" (paraphrasing), sounds easy, but I no longer see my network in the available choices. I see all my neighbors' networks, but not mine.
Cheat then.
Hard wire into the extender for setup. Just make sure to disable the wifi on whatever device you're hardwiring into it so it doesn't default back to the wireless during setup.
