rpunossbc's avatar
rpunossbc
red light blinking on device
hello..we bought an extender ex2700 a couple of days ago..everything was perfectly fine until this morning i noticed there is blinking red light on the device..what does that mean?thank you
  • plemans's avatar
    tough to tell because there's more than 1 led on the device and you didn't give us much info.
    If you go to netgear.com/support/   type in the model number. It'll take you to the support site with the manual that goes over what each led is and means.
      • plemans's avatar
        it means the connection between the extender and a device connecting to the extender is poor.
