ttnoewoc
Jan 28, 2017Star
Repeated Disconnects EX7000 AC1900
My Router worked great for the first 8 months. Over the past number of months, I have been experiencing repeated disconnects from my main router. For the most part, I just told everyone in the house...
DarrenM
Feb 01, 2017Sr. NETGEAR Moderator
Hello Ttnoewoc
Are you talking about the extender the EX7000 or the router the R7000?
DarrenM
ttnoewoc
Feb 01, 2017Star
Hi Darren,
I am speaking about the AC1900 WiFi Range Extender, Model EX7000.
It appears there are a large number of people who have experienced this issue.
It did work great for 8 months or so.
- DarrenMFeb 02, 2017Sr. NETGEAR Moderator
Hello ttnoewoc
You could try to change the wireless channels on your router to see if you get a better connection with the extender also make sure the extender is using the latest firmware.
DarrenM
- ttnoewocFeb 02, 2017Star
Hi Darren thank you. Referencing my original post:
My Router worked great for the first 8 months. Over the past number of months, I have been experiencing repeated disconnects from my main router. For the most part, I just told everyone in the house to go reboot the router, and all was fine.
Over the past month, it became a supreme annoyance so I started troubleshooting:
1) Reset to default and reconfigure
2) Change location
3) Change Configuration (different channels, Fast Lane in all its iterations, etc)
It is just failing and obviously a hardware issue. Firmware is of course up to date and I even replaced my main router to be sure with no change. It will work for an hour or a day, and then just stop connecting to the internet. Interestingly, there is nothing INDICATING it is disconnected, just stops accessing the internet.
NOW I finally get the time to check in with support and I find my warranty is out by 5 days!!! Grrrr.
I loved this router, but if I have to go buy a new one you can be sure I will not be getting another netgear. Do I have any options?
- miketsJun 02, 2017Initiate
Hello, I have the same issue with my EX7000 AC1900, it works ok for 2 days in extender mode, then drops wifi connectivity. Once rebooted, ok again for couple of days before same issue repeating. I have re-configured the channels, and upgraded the firmware but that did nothing. Anything else that can be done? I have purchased my unit in 2015.
Any help is appreciated.
