sunnyorlando
Feb 13, 2018Aspirant
Repeater slows down every couple fo days - needs reboot
Hardware Version: WN2000RPTv3 Firmware Version: V1.0.1.26 I have not upgraded to V1.0.1.4 because as I usnderstand it its only a GUI change. I've had this range extender for a bit over 1 ye...
sunnyorlando
Just in case I decided to update the firmware since in all likeliness someone will tell me to do that first even though it's proabbly unrelated. So that's done - and I don't see anything different.
Now -
When I did the 'upgrade check' the response was that my firmware was up to date.
So I did a manual download and update.
Once completed, I got the message that a new version was available - referring to the old version I just replaced. Basically a downgrade - go figure.
See attached below.
A New Firmware Version is Found. Do You Want to Update to the New Version Now? |
| A New Firmware Version is Found. Do You Want to Update to the New Version Now? | |
| Firmware Version | |
| Current Version: | V1.0.1.4 |
| New Version: | V1.0.1.26 |
| Release Notes:[New Features and Enhancements] Updated Firmware for compliance to the new regulatory standard. [Bug Fix] Security Fixes. [Bug Fix] Fix WPA2 4-way handshake Vulnerability. [Bug Fix] Security Fixes. |
DexterJB
Feb 14, 2018NETGEAR Moderator
Hi sunnyorlando,
Please make sure you do a factory reset after the firmware update if you haven't done it yet. Please keep us posted if the issue persists.
Dexter
Community Team
- sunnyorlandoFeb 15, 2018Aspirant
Hi Dexter,
Thanks... I've done that already - additionally as memtioned in the post I have to reboot regularly anyway to bring the speed back up.
So since I rebooted the day before yesterday after the latest firmware update, I'm now waiting to see the next slowdown - usually 2~3 days in between.
DexterJBwrote:Hi sunnyorlando,
Dexter
Community Team
- DexterJBFeb 19, 2018NETGEAR Moderator
Hi sunnyorlando,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
