sunnyorlando
Feb 13, 2018Aspirant
Repeater slows down every couple fo days - needs reboot
Hardware Version: WN2000RPTv3 Firmware Version: V1.0.1.26 I have not upgraded to V1.0.1.4 because as I usnderstand it its only a GUI change. I've had this range extender for a bit over 1 ye...
DexterJB
Feb 14, 2018NETGEAR Moderator
Hi sunnyorlando,
Please make sure you do a factory reset after the firmware update if you haven't done it yet. Please keep us posted if the issue persists.
Dexter
Community Team
DexterJB
Feb 19, 2018NETGEAR Moderator
Hi sunnyorlando,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
