flashboy
Nov 03, 2018Tutor
Report a bug about EX8000 V1.0.1.186 firmware
When the router restarts, EX8000 cannot automatically reconnect the router and must restart EX8000. If you return to the V1.0.1.180 , It' OK.
flyturbo
Nov 11, 2018Apprentice
That is a good practice, I go over the release notes to see what has been fixed, but not all fixes are disclosed. Hopefully, someone could release a custom firmware for this unit, but with so many issue right of release of unit, I doubt that would ever happen.
flyturbo
I also downgraded to 1.0.1.180 and it seems more stable. Another thing you want to try is don't set your router to auto select the channels for either 2,4 GHz or 5 GHz. It seem to hold up longer.
- amnlupianoJan 11, 2019Aspirant
I have been running firmware 1.0.1.164 for a while. I upgraded to a newer version back in September (don't remember what it was...may have been 180) but began having issues where the internet would drop repeatedly. I discovered others were having the same issue and it was advised to revert back to 164. Yesterday, I decided to try the newest version, 186. It's exactly the same thing...internet drops repeatedly. My devices then jump on my Netgear Nighthawk X4S router (R7800-100NAS). This bug is ridiculous at this point. C'mon Netgear...fix this already! Going back to 164...again.
