ThomasJThomas
Mar 04, 2019Follower
Reseting Router Extender won't reconnect to router
We have used this unit for 3 years without a problem but when we unplugged and moved to a different room it would not reconnect to our home network. We downloaded manual and have gone through all th...
Christian_R
Mar 07, 2019NETGEAR Employee Retired
Hi ThomasJThomas,
Factory reset the extender by pressing on the small black button with a pin and join the NETGEAR_EXT wifi network. After you connect to it, browse to www.mywifiext.net and follow the setup instructions.
~Christian
