Bronco13
Aug 13, 2015Follower
resetting ex6200
I am having trouble with model ex6200. The extender was working fine when I first started using it, but then I changed the original network name and password and now when I try resetting the extender, the extender does not reconnect to the router. Also, if I go to the Netgear genie, it either keeps on repeating or it says file not found.
1 Reply
- nhannNETGEAR Employee Retired
Hi Bronco13,
Please see page 78 of 124 to perform a reset to factory settings: http://www.downloads.netgear.com/files/GDC/EX6200/EX6200_UM_09Jan2015.pdf
and setup the extender with the updated network password.
Also, check to see if your EX6200 is running the latest firmware (page 80).
Let us know if you run into any issues.
NhanN
