eddiev2112
Dec 29, 2018Follower
resetting extender after upgrading wireless router
We recently upgraded our wireless router, and now we cannot use the wifi extender (cannot log into that netword). How can I bring our existing extender into alignment with the new wireless situation?...
anotherbob
Dec 29, 2018Aspirant
Having the same problem, no idea how to fix it either!
- StephenBDec 30, 2018Guru - Experienced User
The simplest approach is to set the router's wifi network to match the old one's network name and password. Then you wouldn't have had to change any of your clients or the extender.
Alternatively you can connect to the extender's wifi network, and then browse to www.mywifiext.net. Then modify the setup to connect to your new router network. If you have trouble getting that to work, then reset the extender with a paper clip and set it up again.
The manual for the EX3800 is here: http://www.downloads.netgear.com/files/GDC/EX3800/EX3800_UM_28May2015.pdf
The EX7000 manual is here: http://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf
- CDunsDec 30, 2018Aspirant
I have an AC750 EX3700 and am having the same problem. I reset the extender and still cant reset up. Any suggestions
- StephenBDec 31, 2018Guru - Experienced User
The same suggestion as I gave to others.
When you reset the extender (not pressing WPS) are you seeing the NETGEAR_EXT network?
