rodrigo8
Mar 17, 2018Aspirant
Restart it self repetitively no stop EX6150v2
My new EX6150v2 (EX6150v2 - AC1200 WiFi Range Extender / EX6150v2) after i set it to be the extender it starts to restart without stopping until i am forced to do the factore reset. I bought 4 unit t...
jvasanth1984
Mar 17, 2018Virtuoso
Hi rodrigo8,
Check for firmware upgrade if any.
- rodrigo8Mar 17, 2018Aspirant
I did the firmware update before this problem.
Also tried to put it close to the router did not solveI set to use only 2G and stopped rebooting. But I need the two bands working together.
I suspect it is some incompatibility with the channels frequency , so the reason the hardware keeps restarting trying to find a free channel.
I tried to use FastLane which for my case I can not use because I have 2G cameras and I need 5G at the same time.
When I returned to the normal configuration 2G/5G together in attempt to stop restart it returned to normal at least for now. 100% sure it's a software problem related to frequencies, I hope Netgear fixes this by the way i'm IT technician.
