mrw538
Mar 19, 2014Follower
RF interference
I have a NetGear WRN3500 and it is dumping intermittent RF interference at: 155.865 and 159.345 plus several more. It is bad enough to set off the auto squelch on a HT1250 Motorola hand held at 15 ...
Retired_Member
Mar 19, 2014Try a re-set or different channel, try a different router, determine if router or client is causing it, take radio in for service or disable auto squelch and set it manually.
