obidos
Mar 27, 2018Aspirant
Router is connected to Extender, but no Internet
I have just purchased a new Netgear WNDR4300v2 router. When I go to connect my WN3000pv2 range extenders, I can connect, but I get a "no internet". I used the standard WPS setup to connect to the r...
jvasanth1984
Apr 01, 2018Virtuoso
Hi obidos,
Looks like your extenders are not setting up successfully using WPS because of which SSID remains NETGEAR_EXT which will be unsecured. Try to set it up using browser method and see if that helps. You can use this link https://kb.netgear.com/24641/WN3000RPv2-initial-installation which will help you better.
