personal515
Aug 09, 2016Initiate
Router light not on
I reset my extender following the manual's directions and all lights are on but the Router and Device lights. When I choose to connect to the EXT wireless, my computer says it's connected but then th...
Fatmrsgeorge
Aug 13, 2016Initiate
I have similar issue. Recently got a new modem from sky so network name and key changed. WiFi extender coming up on device (SAMSUNG TABLET)with new network name but then requests password. When I enter the correct network password it comes back with password incorrect. The power and wPS lights are solid green but the router light is not. The extender is plugged in right next to the router. Can you help or am I simply going to take a baseball bat to the thing ?! I TRIED wps connection. Also tried reset to factory settings. Thanks
personal515
Aug 17, 2016Initiate
I just did a factory reset and then connected it again from scratch using the second option (not the WPS way) - and now it works! So I would suggest trying that...
