oneconfuseddude
Mar 24, 2018Follower
router line LED not lighting
so many problems dont know where to start. wanted to update firmware of extender used on Mac PC. i was able to download the latest firmware file and then i tried to connect iva web rowser set u...
jvasanth1984
Mar 24, 2018Virtuoso
Hi oneconfuseddude,
Can you try it from a different device to see if that helps and also from wired device if any. Also, mywifiext.local doesn't applies for this extender and is only for EX7500 and EX8000 once they are setup. Router LED on your extender is OFF since you haven't setup the extender. I would request you to setup the extender using WPS or browser method by using following links.
https://kb.netgear.com/22035/Installing-the-extender-with-WPS-Wi-Fi-Protected-Setup
https://kb.netgear.com/24276/Initial-installation-for-the-WN2000RPTv3
