Agustinmlotti
Feb 05, 2017Follower
Router Red light .Extender AC1200 (EX6120)
The extender has the router light red so It isn't work well. How can i Fix that?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Agustinmlotti
You can try to factory reset the unit by holding the reset button and then try to set up the extender again to the router via WPS or using the manual setup.
DarrenM
