Majec's avatar
Majec
Router to extender ex6100 connection issues
Router not recogonizing extender?  try to type same password into the EXT_ and doent connect
Do I need to check WPA-PSK [TKIP] + WPA2-PSK [AES] on wireless so router sees extender?
  • plemans's avatar
    Router not recognizing extender or extender not recognizing router?
    Did you set it up with wps or the installation wizard?
    Try the wizard if you used wps. factory reset the extender and run the installation wizard.
    What firmware is on the R6900P?
    Firmware on the EX6100?
    • Majec's avatar
      Majec
      Once I upgraded the firmware on my AC1900 Router the extender worked on the WPS button the extender genie or the mywifiext
      or the IP address: 192.168.1.250 would not activeate  not sure why is there a setting I am missing on the AXC1900 routere?
      • plemans's avatar
        I'm not sure what to even make of what you wrote. You first put that wps work and then wrote about not activating.
        Maybe a better description of exactly what you're doing, what happens would be more beneficial
