Sanix
Apr 15, 2012Follower
Routing does not work
Hi,
I'm using the product WNDR37AV and have two questions:
My modem is connected to an vpn router. I connected that one to the wireless router. The internet works fine for all clients connected to the wireless router. However, I see other clients not directly connected to the wirless access point but to the vpn router.
Is there a routing table I can view to debug the problem?
Why do I have to use no security, if I want to use another access point as repeater. This basically renders this product useless, if you want to use repeating. WEP cannot really be called a secure solution. Is there at least a possiblity that I can limit the access the certain MAC addresses?
- jmizoguchiVirtuosowndrxxx is not access point... it is wireless routers
http://forum1.netgear.com/forumdisplay.php?f=105 - jmizoguchiVirtuosoif you have router and wanted to be on same network then you need to setup wndr as AP
http://kb.netgear.com/app/answers/detail/a_id/965Why do I have to use no security, if I want to use another access point as repeater. This basically renders this product useless, if you want to use repeating. WEP cannot really be called a secure solution. Is there at least a possiblity that I can limit the access the certain MAC addresses?
this well discussed. will NOT change
use extender such as wn2500rpt , wn2000rpt to connect to wndr3700 if you want to extender wireless safely.
