MMAfan1982
Mar 12, 2018Follower
says wrong username after firmware update, wn2000rptv3
I am about to install a new cable modem and i use this extender to reach the garage, I logged in and it said i had a new update so i updated it, now its telling me i have the wrong username, i use th...
DarrenM
Mar 14, 2018Sr. NETGEAR Moderator
When you install your new modem your will need to factory reset the unit anyways this will put it back to the default username and password.
DarrenM
- eduuu2007Mar 18, 2018Aspirant
Same problem here.
I've just updated firmware, did factory reset as suggested and the extender enters into easy setup mode where I select the wifi to extend but I can't select username/password for the web interface of the extender.
When trying the original admin/password it says invalid username.
- jvasanth1984Mar 20, 2018Virtuoso
Hi eduuu2007 MMAfan1982,
Try simple e-mail address without any special characters except @ before domain during setup and see if that helps. If you have already created the account, try to reset and reconfigure it.
