bonzo76
Mar 09, 2016Initiate
Seamless connection?
I have a WN3000RP range extender. I was under the assumption that it connected automatically to my network via wps and I would have a seamless wireless connection through my home. Am I missing somethi...
- Mar 11, 2016
You should be able to set up the range extender's Wi-Fi network to use the same SSID and password as your main network. You will have to log into the extender at mywifiext.net and make the changes.
TheEther
Mar 11, 2016Guru
