eyal27ny's avatar
eyal27ny
Follower
Apr 11, 2018
Seamless Roaming between access points
Hello.
I have two AC1900 EX6400 set as Access points between second floor and a basement (Wired connected via Moca 2.0)
I don't think I get Zero roaming as the connection to the access point stays with the initial Access point.
I also have the G1100 Fios Quantum as the Cable Modem + wireless Router, but I could turn that off.
Is my current ex6400 supports zero handoff (Roaming), if yes then could it be that I need to play with the signal strength?
If no, then which devices I need to use as access points to achieve the zero handoff.
The devices needs the zero handoff are iPhones
  • Hello eyal27ny
    The EX6400 does not have the option to hand off the devices to the strongest wifi signal it will only do this when the device has completely dropped the signal from the extender.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello eyal27ny
    DarrenM
