sdasilva03's avatar
sdasilva03
Second EX2700 extender, devices won't connect
I have 2 EX2700 extenders connected to my router. First one set up no problem, devices all connect to it just fine. The second one appears to connect, all lights go green, and shows up under the Wifi networks on my devices, but they fail to actually connect - either cycling through "authenticating" and "connecting" with no error given, or they give a "network unavailable" error. I haven't been able to figure out why this is happening. Am I missing a step in configurign the second one?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sdasilva03
    Is the second extender trying to connect to the first extender instead of the router? and are the SSID different on the routers and the extender?
    DarrenM
    • sdasilva03's avatar
      sdasilva03
      Both extenders are extending the router, not each other. They have different SSIDs. Now I've found that since connecting the second one, neither extender is working. I'm wondering if it's a setting in my router? I have an ASUS RT-AC66R.
      • DarrenM's avatar
        DarrenM
        sdasilva03
        Im not familiar with asus routers but I did find a emulator and there might be a setting under Wireless then across the top click bridge it has options to add mac addresses of wireless APs for the router to connect to you may just need both extenders Mac address to this list.
        DarrenM
