thowoc
Sep 12, 2016Aspirant
Security configuration
Just configured the extender and it works fine BUT only if configured with no security. If I configure it wirh WPS, I cannot connest to the network, getting the error code/answer "Unable to connect ...
- Sep 14, 2016
Hello thowoc
I would make sure your router is set to WPA2 security and then factory reset the extender and try to do the extender setup again.
DarrenM
DarrenM
Sep 14, 2016Sr. NETGEAR Moderator
Hello thowoc
DarrenM
- thowocSep 15, 2016Aspirant
Hi Darren,
Thanks for your answer.
I've got it working after reset.
However, using the same password as the router didn't work.
I had to change the set-up to another password and it works now.
Thanks again!
Thomas
