thowoc's avatar
thowoc
Security configuration
Just configured the extender and it works fine BUT only if configured with no security. If I configure it wirh WPS, I cannot connest to the network, getting the error code/answer "Unable to connect ...
  • DarrenM's avatar
    Sep 14, 2016
    Hello thowoc
    I would make sure your router is set to WPA2 security and then factory reset the extender and try to do the extender setup again.
    DarrenM
