pdxfunkjunkie's avatar
Dec 07, 2022
Security settings for AC750 extender
Hello Community.  I have a Netgear N600 Wireless Dual Band Router (WNDR3400v2) with two AC750 range extenders in different parts of the house. This setup has been working fine UNTIL we got two new iPhones and a new iPad.  The damn smarty-pants new Apple devices now complain about "weak security" on one of the AC750 extenders and refuse to connect to that one. Only on ONE of the extenders, mind you - and it's the older of the two. My router is set for WPA2-PSK [AES] which I'm pretty sure is the highest security protocol it can support. Here's my question: how can I access the security settings for the "weak" extender? And hopefully upgrade those settings. When I use www.routerlogin.net, it appears to show me only the settings for the main router and not the extender - even though I'm connected through that extender (using an older Apple device.)
  • This is an older post but I am just replying here because I ran into this issue too. The solution is to change the setting for the WiFi password from "Use the same password" to "Use a different password" in the Netgear Extender settings. When you click that, an option appears to change the security type. I did not actually change the password and it was populated with what I had entered before. Not very intuitive, but it works and I don't get weak security warnings on my iPhone anymore when I connect to the Extender.
  • plemans's avatar
    You can log into the router and look at its attached devices page. It should list the extenders by ip address.
    Use those addresses to access them.
    You can check the security there.
    but you probably have them setup properly and its just apple being a pain with the notices.
