chriswalter
Sep 04, 2016Aspirant
security when using ex6000 as an AP
I'm trying to use an EX6000 as an access point with a BT home hub 4 as my main router. The only way I can get it to work is to turn off the security and have the new network I've created unprotected ...
chriswalter
Sep 08, 2016Aspirant
Firmware is up to date and WPA2 security wasn't an option.
Do I need to set it to a specific IP address outside the range of the router's IP addresses?
DarrenM
Sep 09, 2016Sr. NETGEAR Moderator
Hello Chriswalter
You shouldn't have to do that? and WPA2 is not a option on your main router?
DarrenM
